Sharp MX-4501N Hard Disk Drive
  • ExXeroid
    • Jul 2010
    • 56
    Hope Someone can help me, I have a Sharp MX_4501N in my warehouse that my customer wants the Hard Drive from so their IT Guys can scrub it clean. (They need to do it and of course the Sales Guy said it wouldn't be a problem)
    Can anyone tell me where the heck the HDD is in this machine and some pointers on getting it out?
    Any help would be appreciated!
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Back right of the machine (looking at the front). Remove the push-in cover and take out the screw, take off the plate, couple screws in the plate above the finger handles and the HDD is on the back of that controller box.
    • ExXeroid
      • Jul 2010
      • 56
      Thanks!
      Thank You Sir!
      I found it! Great info, I really appreciate it!
      • Akitu
        • Oct 2010
        • 2595
        Always happy to help.
        • ExXeroid
          • Jul 2010
          • 56
          I am trained on a Xerox box called Hodaka, DC222 family and later called Silver Stone ETC. Very similiar design but not anywhere near as easy to get to!
          • grog
            Re: Sharp MX-4501N Hard Disk Drive
            I'm in the same boat but I'm having trouble taking the above description and translating it to the copier. I currently have the back cover plate off but I don't see anything that resembles a "push in" cover. If you could go into a bit more gory detail, I'd be eternally grateful.
            Thanks.
            • Akitu
              • Oct 2010
              • 2595
              Thanks.
              The "push in" cover was the first one you had to remove to get access to the one screw that holds in the back cover plate. There should be one screw above and below each of the finger handles respectively and they need to be removed before the control box can be removed from the machine.
              • grog
                First of all, wow, thanks for the incredibly prompt response! I really appreciate the help. The back cover plate required the removal of a bunch of screws. Lemme ask this, as I look at the machine from the rear with the metal cover plate gone and all the "insides" displayed, where should I look for this controller unit?
                • Akitu
                  • Oct 2010
                  • 2595
                  If you've taken off the rear panel of the machine, you're looking in the wrong place. Looking at the rear of it, on the lower left hand side should be the control box with all the ROM chips and the HDD on the back of it.
                  You'll notice it as a large metal square from your angle.
                  • grog
                    Found it! It's that large swing-out part. The hard drive, as you say, is mounted on the backside of it.
                    Thanks again! You've been a life saver.
                    • Akitu
                      • Oct 2010
                      • 2595
                      No problem. Glad to help.
                      • PASTech
                        • Sep 2010
                        • 192
                        AKITU
                        What's Brown and Sticky?
                        -A Stick
                        • bdcrandall13
                          • Sep 2010
                          • 235
                          I think this is better. She could be my lifesaver!
