Fax kit for mx4501n & mx4101n
  • berg77
    • Mar 2011
    • 10
    Can i use fax kit from the mx4501n into the mx4101n????
  • bilyahn
    • Dec 2006
    • 1470
    The MX4501 uses the MXFXX1 kit and the MX4101 uses the MXFXX2 kit. I don't see where they are cross compatible in the manual but their installation and setup are the exact same. Haven't tried it but knowing Sharp there is probably a ROM version conflict in there somewhere.
    Good luck.
    Bil
    • ZOOTECH
      Senior member of CRS
      • 3375
      Not sure if connector pins match up between the FXX1 and FXX2, but the connector is white for the FXX1 and pink for the FXX2 and should match color connector on the MFP board.
      • lky1978
        • Mar 2009
        • 483
        physically not same
