AR-M451N - using the printer without the AR-EF3
  • vlad_
    • Jul 2008
    • 98
    Good afternoon.
    I have AR-M451N without additional options. Only used the printer. Works fine.
    Is there a program that allows you to set the machine?
    The program "printer status monitor" only gives information about how many paper and toner quantitatively.
    Let me add that without the AR-EF3 function "sleep" not working correctly. The device goes into "sleep" and then he wakes up. Disable RG45 - does not help. What you recommend to address these challenges? except for installation of AR-EF3)
  • igi
    • 1507
    A. Entering the diag mode
    With the power OFF, hold and press the [MENU] key and the [OK] key,
    and at the same time turn on the power.
    B. Selecting diag menus
    Press the [MENU] key to change the diag menu.
    *Press the [OK] key to execute the test.
    *Press [up ] or [down ] key to go to the input menu.
    *Press the [BACK/C] key to return to the previous menu
    hope that helps
    ta
    • vlad_
      • Jul 2008
      • 98
      hope that helps
      ta
      I'm sorry, but the copier AR-M451N not find any button
      • lky1978
        • Mar 2009
        • 475
        igi, your method only work for tiger series.
        • lky1978
          • Mar 2009
          • 475
          vlad,y ur machine not come with ar-ef3?for your situation, i need to try my machine in workshop and then let you know
          • igi
            • 1507
            hi my bad
            how abbout via the web browser
            ta
            • vlad_
              • Jul 2008
              • 98
              hi my bad
              ta
              Through a Web browser?
              How to execute the 25-2, 24....... through a Web browser??
              ta ???
              • bilyahn
                • Dec 2006
                • 1467
                Can't do it via the web browser. Like lky1978 mentioned this series, the ARM355-451-455 did not start out as a printer like the ARM350 series so it needs the scanner panel to get into diagnostics and system settings. Sorry.
                Good luck.
                Bil
                • vlad_
                  • Jul 2008
                  • 98
                  Understood.
                  Hence, as a printer, AR-M451N/351N will work in the blind.
                  All thank you very much.
                  И тебе Игорь.
