MXM160d paper empty message during job but paper in tray
  • sharphead
    • Aug 2009
    • 285
    Ive seen this before on arm207/160, sensor is working fine is this a firmware issue or is there a work around
  • igi
    • 1507
    hi try to feed from bypass if problem gone then its your tray
    sensor or feed rollers home position
    cheers
    • rayjeek
      • Jun 2010
      • 239
      I think I have had a similar problem before and it was the paper feed clutch binding. Change it and see the result.
