After replacing the BLK developer and Initializing It i get this message L4-06 is this a problem with the transfer belt unit??
MX 2300 Error L4-06
Trouble content
When separating the primary transfer belt unit,
change in the separation position sensor
characteristics is not detected within the specified time.
Section
PCU
Case 1
Cause
Harness connection trouble between the PCU PWB
and the separation position sensor
Check and remedy
Check the harness between the PCU PWB and the separation position sensor.
Case 2
Cause
The belt position sensor is not interrupted or it is always interrupted.
Belt separation clutch operation trouble
Check and remedy
Use SIM6-3 to check the belt separation operation.
Case 3
Cause
The primary transfer belt unit is not installed.
Check and remedy
Install the primary transfer belt.Comment
Hello
This is caused by the c clip on the transfer shaft from the gearbox wearing. the only fix is to remove and strip the gearbox to replace the worn shaft. tech bulletin CCE-589
NSFTZ2923FCZ1 is the shaft
LX-WZ0473FCZZ are the poly sliders, 2 requd
Allow 2 hours to do this first time.
BillComment
Hello
bonnie750 is spot on,if you are regestered on the sharp tradenet site there is a bullitin there for this fault.To check remove the transfer belt and manually pull the gear and shaft of the transfer belt lift motor,if you get movement chances are that the c clip has come off.Bit of stripping involved but time and space allowed you should be ok.Comment
