AR-M236 with AR-NC5J network problems
  • b100w11
    Hello there,
    we have a Sharp AR-M236 with a AR-NC5J, a printer & a scanner kit.
    It has some problems with the network, after it's powered up it works for a few minutes and after that dead silence. It doesn't reply to a ping, doesn't send the scanned pages etc.
    The NIC status has the correct TCP/IP settings, IPX, Appletalk and Netbeui are disabled.
    Already changed the hub and the network cable. Using a cross cable works for a longer time.
    It was so untill today, when I tried it in the morning the machine didn't respond to ping anymore even if just power cycled.
    Any idea? Firmware of the AR-NC5J is 1.03.
    Thanks!!!
  • b100w11
    I found out what happened and why the machine doesn't work even for a minute. My colleague is an 1d10t.
    He saw on the Sharp service site that there was a firmware named FW_ARNC5J_VER1.2.bin and thought that it was a smart move to upgrade it. In fact when loaded in the firmware upgrade utility the version is clearly stated as 1.02.00... I found out the "strange version" number when checking the NIC with the forced loader jumper on.
    I looked around the service site at Sharp, but couldn't find the 1.03.01 firmware. (at least on the Italian site) Does anyone know where to find it?.
    PS
    I'm also searching for a very slow way to kill someone
    • b100w11
      Solved, thanks!
      The firmware upgrade solved also some issues we had with accessing a LDAP directory server.
      • CGS
        AR-NC5J
        How can i get the firmware? actually i have 01.01.01
        I visit Sharp website and i don't found it.
        • mickspace
          • May 2008
          • 22
          I think you might have to pay for this site? But I know they have all firmware, manual, drivers, etc https://www.sharp-service.com/login.htm
          this site is good for downloads and it is free, not sure if they have firmware
          Sharp.ca Downloads
          • DINGO
            • 661
            re
            Originally posted by b100w11
            Solved, thanks!
            y
            can you send me the latest firmware and the utility for upgrade of the arnc5j?
            y have the same problem that you have.
            thanks in advance.
            ding-o@sapo.pt
