Server for Networked printer - won't print from another computer if server is off
  • cheeseus
    • Sep 2010
    • 36
    Hello,
    I have just found out that I cannot print from a networked computer (laptop) if my PC is switched off. Apparently it acts like a server.
    The printer is listed (on the laptop) as Sharp AR-M155 PCL6 ON XXXXX, where XXXX is the name of the PC.
    It is of no surprise that if the server is offline printing won't be possible, but the question is WHY does it have to be this way, why does there have to be a server?
    This kind of setting kind of cripples the networked printing option. Is there another way to set up the system to avoid such dependence?
    Both computers run Win 7 x64.
  • igi
    • 1507
    hi
    i dont have this model
    but printing is common
    how do you print network or usb
    if usb you dont have much choise
    if network then install driver on each pc and print direct
    good luck
    • cheeseus
      • Sep 2010
      • 36
      Originally posted by igi
      hi
      good luck
      Hi,
      Thanks.
      I print via network - the signal is sent to the router and from there to the machine.
      The drivers are installed on both the laptop and the PC.
      I don't remember the installer asking me if I want to make the PC a server or not.
      • igi
        • 1507
        hi can you ping the copier from all computers
        if you can then reinstall the drivers and it should be fine
        good luck
        • cheeseus
          • Sep 2010
          • 36
          good luck
          Yes, I can ping the printer. And I can print from the laptop, and scan to the laptop/PC but only if the PC, which is acting as server, is turned on.
          Otherwise, when I try to print from the laptop, I get "server offline".
          Will reinstall and write back.
          • bilyahn
            • Dec 2006
            • 1467
            Don't search for networked printers when you install the drivers. These will be shared printers on the network. Sharps do not show up as "networked" unless shared. Just follow the prompts for the print driver and you should be okay. You can use the default Windows 7 drivers but you will need to manually input the IP address to get it to work properly.
            Good luck.
            Bil
            • cheeseus
              • Sep 2010
              • 36
              Sorted
              I removed the shared printer, then reinstalled the PCL / Postscript Driver - it detected the printer automagically
              Well, before this I tried twice with the MFP driver, choosing "Connected via the network" but the printer was never available (although it showed online)... until I realized I was installing the wrong driver.
              Thanks!
