ARPN1B scrambled hole punches
  • bilyahn
    • Dec 2006
    • 1470
    Have this unit installed on an ARM455N with ARFN7 (unit has been installed and working properly in the same location for 5 years). When doing hole punches the unit will punch the 1st page with 3 holes, 2nd page with 5 holes and all other pages with 2 holes. If I only do 1 page it will puch 3 holes properly everytime. Checked and cleaned position sensors and LEDs, reseated connectors on the board. Has ROM version 6.01. Going to take another punch unit to replace it but was wondering if anyone has seen this before.
    Thank you fo your time and effort in this matter.
    Bil
  • igi
    • 1507
    hi
    does it do it from copier or printing
    if printing may be corupt driver
    good luck
    • bilyahn
      • Dec 2006
      • 1470
      The unit is not set up to print. They use it strictly as a stand alone copier.
      • igi
        • 1507
        hi ok that leaves us to check for dry joints on punch unit
        or connectors that working themself out
        good luck
        • bilyahn
          • Dec 2006
          • 1470
          Thanks igi. Update on this so far is that I replaced the entire punch unit and the replacement unit works fine. Will update as I have a chance to troubleshoot in the shop. Maybe sometime this year!! LOL
          Have a great day.
          Bil
