error L6 on Sharp 5015
  • adhim
    • Jul 2025
    [Error Code] error L6 on Sharp 5015
    hellosomebody pls help me..
    i've problem with my digital copier sharp 5015,there is an error L6.
    what's that mean?what i should to do?
    Thank's for attention and solution.
  • spotlifter
    • Mar 2008
    • 65
    By pressing the start button, you can see the sub code L6-10.
    Polygon motor faulty. Replace it and you are good to go!
    sigpic
    • adhim
      ok,thank's...i'll try.
      • JustManuals
        • Jan 2006
        • 9838
        Just Manuals | The Internet's largest selection of manuals | Instant Downloads
        Paul@justmanuals.com
        • chakiris
          • 22
          Re: error L6 on Sharp 5015
          You may have a polygon motor defect. Replace and you will have an LSU good as new.
          • lky1978
            • Mar 2009
            • 483
            just change the polygon motor, u also can use ricoh aficio 1018polygon motor. there are compatible.
