Sharp Printer Status Monitor Help ?
  • scomeau1
    • Mar 2011
    • 100
    I just got my Sharp MX-M620N up and running via USB port and are trying to get the Printer Status Monitor working.
    But I have no luck so far.
    Does the Printer Status Monitor need the Network connection to work or can it be run via USB ?
    I also installed the Printer Administration utility but it's not showing any printers installed.
    Does this also need a Network cable to the MFP or can it be run via USB Port ?
    Thanks for any help you can give me.
    Scott
  • scomeau1
    • Mar 2011
    • 100
    Just looking for some help hear on this problem if anyone could help ?
    Thank You !!!
    Scott
    • ecarats
      • 21
      Yes, it must use the cat5 network connection for both.
