Service or "Crop" codes
  • Mezagog
    Have this Sharp AR-235 sitting in my office that I need to get into Service mode with and for the life of me I can't remember the set up. I know the older ones were Clear-Interrupt-0-Interrupt. Just need those four magical buttons to push............................Preferrably in order.
    Thanks guys
  • ZOOTECH
    Senior member of CRS
    • 3375
    Press # - Interrupt - C - Interrupt, this should get you in; most test commands are same as other Sharps.
    • kisha
      al sharp 1642cs
      does anyone how to remove the flashing drum light? I replaced the drum with a new sharp drum and it still has a flashing light. I called sharp for support and they told me to take it back to the store and replace it. I did this ater arguing with Staples for about an hour and the light is still flashing. I am sure that Staples will not return this drum and I am out of $167 please help me remove these lights? Is there a code that I must enter to remove the light? What are the codes for al sharp 1642cs?
      Thanks in advance
      Kisha
      • ZOOTECH
        • 3375
        Test command 24 sub 7 generally clears drum counter.
