Sharp MX-M620N Scanning Question ?
  • scomeau1
    • Mar 2011
    • 100
    After I have the document scanned and stored on the hard disk of the copier how can transfer the file back to the PC ?
    I'm using the USB cable and don't have the network setup on the copier.
    Thanks for any help you can give me !
    Scott
  • xmasvn
    • Jul 2009
    • 70
    must use network without network you can't not scan as well in pc you have to install sharpdesk, when you install sharpdesk it will automatic scan on your network have any photo sharp have scan it will add to the list or you can choose with one you want to use with this pc
    • efe311
      • Oct 2008
      • 114
      To enable the scanner function, the product key must be acquired.
      • For models on which the printer and network functions cannot be
      used, a printer expansion ROM and a Print Server Card must be
      installed in advance.
      THIS WORDS FROM THE MANEUAL SERVICE
      • efe311
        • Oct 2008
        • 114
        • xmasvn
          • Jul 2009
          • 70
          usually the MX-620N go with network card (that is default from sharp) they can use network printer , maybe check careful scan option install or not easy way to check that by press image send on panel if they display address book it mean scan have been install if not they will display this option not active or some thing like that
          • scomeau1
            • Mar 2011
            • 100
            I checked that the network card is installed and it is: Now I guess from the above post that I need to see if the "printer expansion ROM and a Print Server Card" is installed ?
            Is there a menu and sub menu that I can find out is they are installed in the service menu ?
            Thanks Scott !
            • ZOOTECH
              Senior member of CRS
              • 3375
              Simulation 22-10 will show what options the machine has. A look at the MFP board will let you know if the NIC is present.
              • ecarats
                • 21
                Scanning to the copiers hdd is to be able to print the same document over and over from the copiers hdd. Not having to run an original over the optics.
                • CopierTechofOmens
                  Agitating Artificer
                  • 268
                  Re: Sharp MX-M620N Scanning Question ?
                  Scott
                  Once the MFP is visible on the network just imput the IP address of the copier into a web browser. This will bring up the embedded web page. On the left click document filing. There you can access your saved scans and manage them.
                  sigpic
                  • bilyahn
                    • Dec 2006
                    • 1470
                    If you move them to your PC (saved to PC) from this page they are saved as a .bin file on your PC since this is how the copier sees it, not as a tiff or pdf!!!!
                    Good luck.
                    Bil
                    • mojorolla
                      The Wolf
                      • 2609
                      SIM 26-10 is used to turn on scanner trial mode. It will allow you 500 network scans. After that, you will need the optional expansion parts.
