ar-m451n crashs.
+ More Options
Posts
  • DINGO
    • 661
    ar-m451n crashs.
    Good night.
    i have a ar-m451n, that is leaving me crazy.
    Sometimes (intermittent), stop to work, and jams paper.
    after taking the sheets the copier reboot and loses al work....
    Do not show any error code,i only have a coincidence in this copier
    that is, this copier gives severals f2-02, and damage the chip toner
    i already do everything that i saw in this forum without look, and the copier
    as the latest firmware
    Somebody knows if there are some boletin about this?
    regards
  • lky1978
    • Mar 2009
    • 483
    dongo, check the earth spring in the ps unit. Should be 2 springs there.
    • DINGO
      • 661
      hi friend, thanks, but i alreadky swapped the ps unit.
      saty weel, good work.
      • JustManuals
        • Jan 2006
        • 9838
        Just Manuals | The Internet's largest selection of manuals | Instant Downloads
        Paul@justmanuals.com
        • divad2k1
          • Sep 2010
          • 147
          Do you have this problem when printing only or also when copying ?
          • DINGO
            • 661
            in the two conditions.
            regards
            • bilyahn
              • Dec 2006
              • 1470
              I have had a similar problem but upgrading the ROMs like you have done has always fixed it before. Have you tried a different set of ROMs? There is not a bulletin on this that I have seen.
              Good luck.
              Bil
              • igi
                • 1507
                hi
                something to look for
                1-memmory
                2-h.drive
                3-cluthes on the main drive unit
                good luck
                • DINGO
                  • 661
                  ok, the only thing I have not tested was a diferent set roms.
                  i will do it, thanks
