c4-00 error on mx3100
  • gregu33701
    • Oct 2008
    • 31
    Anyone point me in the direction of a c4 error on m3100 all I have is 350 355 manuals
  • ZOOTECH
    Senior member of CRS
    • 3374
    You have a problem with the PTC unit.
    • gregu33701
      • Oct 2008
      • 31
      Thanks, could that lead to a -10 subcode as well?
      • DavePo
        • Jul 2008
        • 303
        C4-1C0 C4-00
        CC
        C4-00 PTC no control
        Trouble content
        Detail PCU
        Cause The engine soft SW8-3 in SIM55-1 is set to "1".
        The PTC control is not executed. (The PTC does not
        operate.)
        When the engine soft SW8-3 in SIM55-1 is set to
        "1", the PTC output, the heater control, and the error
        detection are disabled. When this setting is made in
        case of a PTC unit trouble, the PTC function is
        disabled regardless of the PTC trouble and printing
        operation can be performed.
        Check & Remedy Set the engine soft SW8-3 in SIM55-1 to "0".
        (The mode returns to the normal PTC control mode.)
        This is from manual but I would suggest you replace PTC with the newest version and reset counter under maint items.
