How can I use sharp Ar-336 as a printer ?
  • Ahmad Abdo
    • Jun 2025
    someone told me its possible but there isn't a usb port or parallel port ... how can I do this ?
  • DINGO
    • 661
    Friend, first you must take an opcional print board, AR-PB2, and only work by a parallel port.
    • Discountcopiers
      • Jun 2011
      • 52
      you have to purchase the PWB assembly. I have two used ones I would like to sell. You may need the service manual to properly code the machine for this configuration. let me know, thanx arnie
      • DINGO
        • 661
        HI
        make sure the version of firmware. is compatible with the arpb2.
        good look
