Sharp mx2700 sub code
+ More Options
Posts
  • gitana1983
    • Mar 2009
    • 141
    Hi to all!
    Quick one, how do i check the sub-code on a sharp mx2700? Can't find it in the manual and i'm in a hurry.... Any help is appreciated!
    Thanks!!
  • lky1978
    • Mar 2009
    • 482
    Originally posted by gitana1983
    Hi to all!
    Thanks!!
    Are you asking for error code or simulation code?
    For error code,sub code appeared follow by the main code. for an example H4-00-->main code is H4 the subcode is 00
    for simulation, sub code ll list out after you enter desire main code.
    hope can help you
    • gitana1983
      • Mar 2009
      • 141
      ERROR CODE:
      Currently is showing F2 but not letting me see the subcode, how do I get it?
      • Akitu
        Legendary Frost Spec Tech
        • Oct 2010
        • 2595
        Either the machine settings print (22-6) or the error log print (23-2) will show you relative error codes and sub codes. 23-2 in more detail than 22-6.
        • lky1978
          • Mar 2009
          • 482
          try your luck in simulation 22-4 trouble history.First time i see this happen without any subcode
          • gitana1983
            • Mar 2009
            • 141
            Thanks!!
            • Ditchman
              • Feb 2011
              • 51
              Re: Sharp mx2700 sub code
              I have also a 2700 that is working properly but showing message F2, anybody know why?
              • Akitu
                • Oct 2010
                • 2595
                Almost all of the F2 codes are related to toner and pro-con. Depending on the sub code it could be any number of things, hard to make a guess with just F2.
                • ZOOTECH
                  Senior member of CRS
                  • 3375
                  Need the sub code to really help you out - follow the advice above for finding sub code.
