Sharp / Toshiba e150 with "E7-11" Please help
  • CCS
    • 266
    e150 "E7-11" help
    I have this one e150 in the field that keeps intermittently coming up with "E7-11", turn off/on and goes away sometime for days, or sometime just for a few copies.
    I have done general cleaning of optics and such, code keeps coming back.
    Manual says something about CCD white level trouble, what does that mean actually ?
    Also says "dirt on shading plate" for E7-11, what exactly should I clean ???
    I have several of these machines in the field, never this problem, please help
  • igi
    • 1507
    hi all optics
    lamp,mirrors,referrence mylar ,ccd unit,
    lastly firmware upgrade,will do good too
    good luck
    • Dark Helmet
      • May 2009
      • 845
      Have you tried taking the screws off the top of the CCD unit and cleaning the mirrors inside? On the Sharp machines ive worked on they tend to get this film and it clouds the mirror. There is one little mirror hidden below the CCD lense. You can clean it with a q tip or remove the mirror from the back of the CCD.
      • Horologydoc
        • Jun 2011
        • 61
        Clean the rail the the scanner carriage rides on and regrease it. The scanner hesitates when that dries out and causes that code. Your will see that the lube on the rail has turned black and dried out.
        • mojorolla
          The Wolf
          • 2608
          Don't forget the white reference strip on the glass.
          • CCS
            • 266
            Thankyou
            • rayjeek
              • Jun 2010
              • 239
              Change the scanner pwb with a modified one to resolve your issue.
              • JustManuals
                • Jan 2006
                • 9838
                This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
                Just Manuals | The Internet's largest selection of manuals | Instant Downloads
                Paul@justmanuals.com
