MX-4101N & Fuzzy Fonts
  • sacoward
    • Jun 2011
    • 19
    I am having an issue printing from Acrobat. I am printing using Acrobat's built in booklet printing. I am printing from their using the PCL driver set up to saddle stitch. If I use the landscape image orientation in the PCL driver settings everything looks great, but the back of each booklet page is upside down. If I select portrait, the booklet prints out properly but the fonts are no longer crisp. Any ideas? Thanks!
  • mojorolla
    The Wolf
    • 2626
    Using Adobe ver 10? Try rolling back to ver. 9.
    • sacoward
      • Jun 2011
      • 19
      Is this an known issue with Adobe X . . . I hate to go through the pain just to check. thanks!
      • ZOOTECH
        Senior member of CRS
        • 3375
        Whenever I have a customer that is not happy with the font quality, I have them change the font settings under the advanced tab of printing preferences to "Download Fonts" rather than the default "Resident Fonts". It might work for you.
        • sacoward
          • Jun 2011
          • 19
          Alright, so that helped quite a bit. I was able to install 9.4 on top of 10. Printing the same file there is a pretty dramatic difference. 9.4 is by far better, but there is still not quite crisp. Even with 9.4, printing in landscape looks quite a bit better than portrait. Any ideas why this may be?
          • sacoward
            • Jun 2011
            • 19
            Thanks for the suggestion . . . I just tried that and it did not seem to have any affect.
            • mojorolla
              The Wolf
              • 2626
              Are you using PCL6 drivers? You could try dropping down to PCL5c.
