Sharp mx -2300N Replaced Black Cartridge and F2 -40
  • arcdigi
    • May 2010
    • 32
    Replaced Black Catridge when asked and now getting an F2-40. Can't see anything wrong.
    Checked the connections that the service manual says.
  • mojorolla
    The Wolf
    • 2606
    There are 3 bulletins regarding this model and code. MFP-TB323R, MFP-TB296, and MFP-TB-352R. On monochrome, you can run skyshots to draw down the toner in the DV unit. The code only appears if the TCD_K value is below 26. You can check it is SIM 25-1. A black developer change should fix your error.
    • arcdigi
      • May 2010
      • 32
      Actually the TCD_K under 26 or above 231...which i found out mine was at 255 on middle setting 239 on the low settling......it is fixed as of today...cleaned everything and new black cartridge....
      • sharphead
        • Aug 2009
        • 285
        The tech bulletins suggest changing the process electrode cover and charge corona which will offer a complete fix
