mx3110 energy save
  • Smrekca
    • Jan 2011
    • 23
    mx3110 energy save
    hi,
    one problem with the MX3110. when i change the energy save settings it has no affect. the machine is still going into sleep mode after 1 minute. i even tried to change the firmware. any idea?
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Could potentially be a memory issue... Are the settings changing back to 1 minute after you leave the menu?
    • Smrekca
      • Jan 2011
      • 23
      no, the setings are staying changed ,but no affect to the device.
      • Akitu
        • Oct 2010
        • 2595
        Try changing the default energy save settings from "Eco Mode" to "Use System Settings" and set the timers, by default the Aries machines are in Eco mode and will always turn off after 1 minute unless the setting is changed to Use System Settings instead, then it will use your timer values and not the default 1 minute BS.
        From a reliable source.
        • Smrekca
          • Jan 2011
          • 23
          thanks for your quick reply
          that was the first thing i tried , but there was still no change. it seems that the eco mode is still active even i have changed the settings.
          • Akitu
            • Oct 2010
            • 2595
            Have you tried setting to follow power management instead of normal or eco mode?
            • ZOOTECH
              Senior member of CRS
              • 3377
              Originally posted by Smrekca
              hi,
              I personally haven't been to class on the Aries, but one of our techs went to the shortened 3 day class. As he understood the energy save thing, no matter what you set the power management time for it would go into sleep mode after 1 minute. Perhaps the terminology is what's causing the misunderstandings.
              • ZOOTECH
                • 3377
                I stand corrected, as Akitu posted, set the energy settings to "Follow System Settings" and set your timers in the "Power Management Settings". The newbie tech that went to class quoted the Sharp default timers.
