I am trying to figure out how to pre-program some default settings on my Image Send Screen. When in the Copy mode, you can press then "P" key and select a Job Memory number to save your settings. I can't find a way to do the same when you are in the Image Send mode. I am trying to default my Image Send mode to have "preview", "blank page skip", and "2 sided" as a default or at least a program so I dont have to go in each time and set these everytime I scan something. I noticed in the webtools under Job Programs, you can set your copier ones here as well as on the machine. It also has a tab for Image Send mode but my add button is grayed out. Does anyone know how to actually set job memory programs for the Image Send mode, or does anyone not have this section grayed out on their webtools? I am wondering if there is just a setting I need to set to get it to activate this button.
