Updating Firmware on an AR-M205
+ More Options
Posts
  • solinar
    • Aug 2025
    Ive got an AR-M205 connected to a PC freshly formatted with Windows XP Pro via USB in the the USB 2.0 slot on the copier. The latest drivers are installed and the printer shows up as a valid printer and scanner (and works to print and scan).
    I'd like to update the firmware in the hopes that I will be able to not lock up the machine when attempting to scan in color, as well as have the machine scan properly once I upgrade the PC to Windows 7.
    I've got the latest firmware image posted in another thread for the AR-M205 which includes the sharp integration maintenance program. When I run the program, I select the AR-M205 and it takes me to a new screen which says "The copier is not turned on."
    I have also tried using the program on a fresh install of Windows 7 (x86) on the same PC, when hooked up via USB with the same results.
    Any clue as to what I am doing wrong?
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: Updating Firmware on an AR-M205
    Do you have the instructions for the firmware upgrade? If not, send a PM with you email address and I'll send the 3 pages of instructions.
    • solinar
      That would be excellent. PMing now.
      • vladis
        Hi.
        I need the instructions for firmware update too because I am still getting E7 / 11 error.
