Sharp XM 2700 Hardrive instalation
  • gideon
    • 283
    I'm going to install new hard drive, for formating simulation 62-1 the book warren me "Be sure to format the HDD in FAT32" can't find what it means in the manual, any idea? Thanks.
  • igi
    • 1507
    Re: Sharp XM 2700 Hardrive instalation
    hi
    you can try direct in the copier and format full format with test command
    or format in the computer first and then put in the copier,your choise
    good luck
    • mojorolla
      The Wolf
      • 2626
      FAT32 refers to the file system. The other common one being NTFS.
      • JustManuals
        • Jan 2006
        • 9838
        Me thinks this guy is totally lost.
        • gideon
          • 283
          Thanks for your replies, I installed the HDD and got U2-05, run simulation 16 and copier worked. Thanks again.
