al sharp 1642 cs
  • kisha
    • Sep 2025
    al sharp 1642 cs
    does anyone how to remove the flashing drum light? I replaced the drum with a new sharp drum and it still has a flashing light. I called sharp for support and they told me to take it back to the store and replace it. I did this ater arguing with Staples for about an hour and the light is still flashing. I am sure that Staples will not return this drum and I am out of $167 please help me remove these lights? Is there a code that I must enter to remove the light? What are the codes for al sharp 1642cs?
    Thanks in advance
    Kisha
  • lkrsardis
    • Dec 2007
    • 316
    drum reset
    good morning,
    Try this, Enter service mode like this. enter # * clear * then 24 print key 7 print key then cycle the machine off and on. let me know if it works.
    Have a good day.
    Like the United States Postal Service It's a miracle it works!
    • bisiawoeyo
      • Dec 2007
      • 65
      The Answer given above is correct
      the answer that guy gave above is correct.
      If you follwo the instruction is followed then u have a solution to the problem.
      Cheers!
      Bisi awoeyo
