C1-14 on MX3100N
  • rayjeek
    • Jun 2010
    • 239
    [Error Code] C1-14 on MX3100N
    I have a customer who just reported C1-14 trouble code. Its got to do with colour main charge as per handy guide.
    Has anyone ever got this code on MX3100N.
  • JustManuals
    • Jan 2006
    • 9838
    Re: C1-14 on MX3100N
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Paul@justmanuals.com
    • Bani
      • 34
      I had the same problem, replaced all three Color MK-Kits an machine was OK.
      • rayjeek
        • Jun 2010
        • 239
        Problem solved. On arrival noted Cyan toner was not fully inserted. inserted same and popo machine and code went away. However. print out from sim64-1 was faded in yellow top to bottom in the middle portion suggesting Y drum being the culprit. I replaced the Y drum unit, updated firmware and calibrated ok.
        • sharptech
          • May 2011
          • 40
          You may have a yellow laser shutter not opening far enough problem. This can be a intermittant problem. This a known problem on this model.
          Your shutter solenoid may be getting weak or the shutter mechanism is dirty and needs to be cleaned.
          T.G.G.
          • Froota
            Field service tech.
            • 129
            To give some feedback on this thread....:
            I also had this problem on a mx-3100 today, and the problem was solved by replacing the three mk's.
            Thx for the hint!
