E7-03 -> Sharp MX-550N
  • mubtuhogar
    • May 2009
    • 13
    [Error Code] E7-03 -> Sharp MX-550N
    Hi,
    I recently purchased a Sharp MX-550N off an auction. However, whenever I turn on the unit I get this error message:
    "CODE: E7-03 Call For Service"
    I looked up the error on the service manual and it is related to a Hard Drive Failure. However, when I try to put the number 62 in the panel to access the Hard Drive Section and try to do a format, it seems like the number 62 is blocked. I can access all other numbers except 62.
    This got me thinking, the Copier has a sticker on it that says "Media Removed" because since it was bought off an auction they must delete all off the previous owners data and information. To this effect I think that they must have taken off the HDD from the Copier. If that's the case I need the answer to these questions:
    1. Where is the HDD located so that I can verify it was taken out or if there is one already there? (Please be detailed on the location cause I', kinda of a newbie when it comes to this )
    2. Let's say there is no HDD, I would need to know what type of HDD does the copier require and what size in GB does it support. (If you can provide a reference to where you found that info, it would be plus).
    3. If I purchase the new HDD, do I have to call in a technician to install it and perform the preliminary steps or is that a D-I-Y kinda thing?
    Thanks Again,
    W. Maldonado
  • lky1978
    • Mar 2009
    • 483
    Re: E7-03 -> Sharp MX-550N
    possible the previous user take out the hard drive due to confidential issue. Try to input the simulation in copy mode, #*c* 22 start 10 start to check the hard drive exist or not.
    if does not exist,buy a new hard drive and format it.the small dragon only need 80gb ide 3.5"hard drive
    • mubtuhogar
      • May 2009
      • 13
      Perfect. I will try this out. However, can you point me to where the hard drive is located? Because when I install it I need to know where it goes
      About the Hard Drive, I read that the copier bring by default a 40GB HDD. How can I confirm if its an IDE or SATA Drive?
      • lky1978
        • Mar 2009
        • 483
        i think that more easier to find 80gb ide hard drive if compare to 40gb hard drive today.you got service manual for these model?
        • mubtuhogar
          • May 2009
          • 13
          Yes. But how do you know that the Hard Drive is IDE and not SATA? I just need to confirm this. I checked the Service Manuals... I checked online and everywhere and I can't seem to find where it states that the Sharp Copier requires an IDE or SATA Drive.
          Where is the location of the Hard Drive? I checked the Service Manual and it does not display the location. However, I found that it does tell you where the HDD Fan is... so I assume that the Hard Drive must be close to this Fan.
          Can you confirm if the Hard Drive is SATA or IDE by showing me some literature of the Copier? Sorry to question your answer but I just want to make sure I purchase the correct hard drive
          Thanks,
          W. Maldonado
          • mubtuhogar
            • May 2009
            • 13
            Just confirmed with Sharp. It bring my default a 40GB HDD 3.5" IDE
            Now... Do I just format it on the PC and install it to the Copier? Do I need to do any special formatting on the Hard Drive? (Like create specific folders, etc)?
            W. Maldonado
            • hekotez
              • Jan 2007
              • 91
              Thru sim 62 you can format the HDD. If still you want to format it thru the PC it must be in Fat... Do not create anything... The machine does that by herself.
              • mubtuhogar
                • May 2009
                • 13
                Hi,
                The thing is that I used an Old IDE 40Gb HDD from an old PC. It has files in it. I am going to format it to install a blank HDD to the Copier.
                • mubtuhogar
                  • May 2009
                  • 13
                  Hi,
                  Just wanted to stay that the Copier is working great now. Wanted to thank you all for your prompt responses and for helping me out in solving this issue.
                  You guys saved me a few hundred $$$ on getting a Sharp Technician over here!
