MX-M283
  • otuvak
    • Aug 2010
    • 102
    MX-M283
    Have a customer that says there network is set to 100base-tx and full duplex. Machine system status report shows:
    Link status: 100BASE-TX
    Duplex mode: Half
    Machine is right out of the box. Went there today to do TT-20159.
    Sim 55-03
    Set SW no: 6
    Data:1 to = 1 disables auto negotiation
    SW 6-2 is defaulted to 100basetx
    SW 6-3 is defaulted to Full duplex mode
    When I changed to disable auto negotiation the machine link light on nic card would not light up. I could no longer get into admin mode in system settings as well. Any suggestions? Thanks
  • igi
    • 1507
    Re: MX-M283
    hi
    1- put all setting to the original conditions,make sure the nic still works correctly
    2-if yes set your bits to auto negotiate,it will find the correct speed by itself
    good luck
