MXM260 Developer Spillage
  • redserv
    • May 2010
    • 307
    hello again guys, i went to one of my clients this morning, i was told that the customer was getting an ERROR F2-02, upon checking i saw it was some type of toner abnormalty, i also saw a bullentin TT2008 that says the toner gear could possibly cause this error as well, when i got to the customer i saw alot off developer dumped out of the DV unit, and the copies was pretty much messed up, when i looked at the developer inside of the the dv unit, it looked "light grey" in color
    this copier is about 3 mths old, i need to find out what i should do next, should i change High voltage pwb, new drum, developer etc? thanks in adavnce guys hope to hear from somone soon
  • JustManuals
    • Jan 2006
    • 9838
    Re: MXM260 Developer Spillage
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Paul@justmanuals.com
    • divad2k1
      • Sep 2010
      • 147
      You need to replace the dev for sure. ( reset counter, calibration)
      Make sure your drum is not missing coating on both end, if so change it.
      Clean charge and surrounding.
      Thats what i would do first and see if problem comes back.
      • redserv
        • May 2010
        • 307
        ok i will change the DV unit, is it too soon to be thinking about swapping a new main charge unit, High Voltage PWB and maybe the transfer roller?thanks again for your help.
        • divad2k1
          • Sep 2010
          • 147
          A bit too soon for the hvps in my opinion.
          • redserv
            • May 2010
            • 307
            ok thanks for the feedback appreciate it
            • jon jennings
              • Aug 2011
              • 51
              If it pulled the developer out of the unit the main charger is most likely the colprit. it is just pulling the toner out of the developer the contacts for the right door is most likely the problem.
              • redserv
                • May 2010
                • 307
                yep, it pulled most of the developer out of the unit, and the developer was really light grey in color, i will look at the main charge and see if maybe i can swap one out, thanks again really appreciate the feedback
                • jon jennings
                  • Aug 2011
                  • 51
                  Was there a resolution to this? Now I have one doing it. I am going to try the high voltage board. If anyone can think of anything else please respond.
                  • redserv
                    • May 2010
                    • 307
                    i changed new Developer Unit, High voltage Pwb and developer, its at the customer site approx 2weeks now without any problems, goodluck
                    • jon jennings
                      • Aug 2011
                      • 51
                      Thank You.
                      • pana.techn
                        PANASONIC SERVICE TECHN
                        • Mar 2008
                        • 33
                        Did your problem return? as I to am having the same issue, I was told it was a grounding problem and I replaced the dev and checked all grounds but it is happning again less than 1 week after the dev change. Did you ever find out if it was a high voltage pcb or the dev unit?
                        Thanks in Advance
                        • redserv
                          • May 2010
                          • 307
                          well it has been months since i did the job and changed the high voltage pwb, so i can safely that the problem is gone, no more spilling developer, hope this helps
                          • Grebom
                            • Oct 2012
                            • 5
                            Can you tell me if this is the part number you replaced for the High Voltage PWB - RDENU0058QSPZ
                            Thanks!
                            • lky1978
                              • Mar 2009
                              • 482
                              always take care for the dv unit seal, when the seal curl, it ll "guide" the developer come out.
