machine is 2120j,but computer show 5516s??????
  • minolta1054
    • Aug 2025
    I have a problem with sharp ar 2120jwhen sharp connect to pc, show found new hardware 5516s on the pc and not print.this problem after reset with 88-1 code.thank you.
  • JustManuals
    • Jan 2006
    • 9838
    Re: machine is 2120j,but computer show 5516s??????
    Sounds like you botched a firmware upgrade.
    • igi
      • 1507
      hi check sim 26 and set to correct model
      good luck
      • minolta1054
        good luck
        no change.
        sim 26-7 only for show model and can not change other model.
        thank you.
        • igi
          • 1507
          hi
          is sim 26 shows the correct model
