sharp M620u service call code: F2 only
  • remielee
    Technical Analyst
    • Mar 2010
    • 140
    hello guys,
    i have some problem of my machine sharp M620u theres a service call appear on the screen (code: F2) the copier is still working but it produce light copies, i try to remove the toner cartridge and change the chips on it but still the problem occured, i try to reset simulation 14, 16, and 17 still no hope. do you have some idea guys about the said code? all your help would be appriciated i will wait for your reply guys.. thank you in advance to all.. godbless and more power guys..
  • ZOOTECH
    Senior member of CRS
    • 3378
    Re: sharp M620u service call code: F2 only
    Originally posted by remielee
    hello guys,
    What is the sub code? It could be in the toner sense area, the drum cartridge itself, or the process control (ID/DM sensors). I would clean up the drum unit and run TC 44-2.
    • mojorolla
      The Wolf
      • 2639
      If you can, print SIM 22-6 or go into SIM 22-4 and look at the error log. It will list the sub code.
      • remielee
        Technical Analyst
        • Mar 2010
        • 140
        thank you guys for the quick reply, theres no subcode that appered on the screen only F2, i will try all your advice guys and i will reply as long as it was fix or not. thank you so much more power to all of you guys..
        • Dark Helmet
          • May 2009
          • 868
          By any chance did you take the drum out? If you forget to plug the little connector on the back of the drum frame back in after you open it up you will get F2 codes and light copies.
          Double check that connector and then as ZOO said make sure it's clean and recalibrate it with 44-2
          • remielee
            Technical Analyst
            • Mar 2010
            • 140
            hello guys,
            regarding on the machine code F2 problems before, now its okey and the trouble is gone thanks to all of you guys i apply all your advice until i found out the problem. i do the 22-4 and 22-6 to know the subcode then i saw the history f-31 and f-02 the toner cart is new installed thats why i concentrate at the drum sensor cause before the copies is light then i found out it is dirty i clean it then run the 44-2, after that it works fine no code appear.
            thnks to all of you guys you are so awsome!! mission completed!!!!
            • remielee
              Technical Analyst
              • Mar 2010
              • 140
              thanks to sir mojorolla the first one that reply on my thread giving ideas and advice, to sir zootech for the additional advice to know exactly the history of the codes and the subcodes, and to sir lawrence for the additional comments and advice thanks and more power! appreciated a lot!!
