Sharp AR-C262M cyan and yelllow not correct
  • jifop
    • Jul 2025
    Hi guys, I have an issue with a Sharp MFP, basically the print output is fairly horendous as there appear to be chunks missing from the yellow and cyan runs. I have attached the calibration page to give you an idea of what is going on! it was doing this a while back but after a good clean it stopped for a day but now its back again to haunt me.
    I have replaced both imaging drums and this seems to make no difference!
    any help would be much appreciated
  • divad2k1
    • Sep 2010
    • 147
    Re: Sharp AR-C262M cyan and yelllow not correct
    Have you tried to replace both toner cartridge ?
    • jifop
      not yet no, would they be a likely culprit?
      • DavePo
        • Jul 2008
        • 305
        I agree with divad2k1, also wouldnt hurt to check the drum drive gears for cracks.
        • lky1978
          • Mar 2009
          • 483
          nightmare machine. this model i most hate....waste money,waste time...i dont know why sharp never pull back this model for exchange or refund?!?!
          • jifop
            thanks guys, it is pointing to the toners, if i shake them and do a print the first one is fine (although missaligned) the second has no yellow and the third no cyan so i guess even though half full the toner must be screwed! I'll order a new set up
            thanks
