Sharp MX-B401 Does Not Pull Original Immediately
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    [Misc] Sharp MX-B401 Does Not Pull Original Immediately
    It does not matter how slowly you go as long as you do not stop. –Confucius
  • mojorolla
    The Wolf
    • 2618
    Re: Sharp MX-B401 Does Not Pull Original Immediately
    Try swapping the doc feeder unit. I had one last year that had everything changed or swapped out of it, so all that was left was the frame. My DSS was stumped and after replacing the entire feeder, problem went away. OurS would hang up during a scan and just sit there until reboot. Do all the CCD tests in simulations? Firmware up to date?
    • Dark Helmet
      • May 2009
      • 850
      Do a color scan of a test chart. I had a machine that would take for freaking ever to pull from the document feeder. It would sit there for almost 5-10 seconds bouncing the optics back and forth then finally pull the sheet.
      Mine had a screwed up CCD. Sharp had me replace the entire optics section.
      Please check the sample.pdf i posted on page 2 of this thread. http://www.copytechnet.com/forums/sh...canners-2.html
      If your scan looks messed up like that you have optics problems.
      If your machine has old firmware and your are using IMAGE SEND with LONG SIZE as the original type the machine will freeze up and only a reboot will get it going again.
      • mojorolla
        The Wolf
        • 2618
        A Frontier series machine with a bad CCD you say ?.....hogwash!
        • igi
          • 1507
          hi all
          i had the same problem on a smaler coper,maybe related
          is there a setting for copy lamp to stay on all the time,if is swith it on
          good luck
          • The Otrain
            • 54
            Isn't first copy time using the RSPF about 10 sec with this model? I thought that was normal.
            • Dark Helmet
              • May 2009
              • 850
              I would agree with the FIRST copy on startup but ive seen them do that copy after copy.
              • The Otrain
                • 54
                Whoa....now that might be a problem. Anything on IDNC? Firmware up to date etc.?
