SOFTWARE
  • abbas
    • 39
    SOFTWARE
    hai,
    i need ar-5127 windows 7 printer driver. somebody know about this similiar driver pls send a link
  • JustManuals
    • Jan 2006
    • 9838
    Re: SOFTWARE
    Go to the Sharp site and get it yourself.
    • abbas
      • 39
      Re: SOFTWARE
      i just checked sharp website but there is no ar 5127 model. witch one is the same model driver splc driver
      • bilyahn
        • Dec 2006
        • 1470
        Re: SOFTWARE
        Looking at the picture of the machine it looks like it is an AR275, BUT there doesn't appear to be a Windows 7 driver for it. You can use the Windows update in the printer setup to find the driver in Windows 7. I have done this for a lot of older copiers that are no longer getting driver updates.
        Good luck.
        Bil
        • bonnie750
          • 302
          Re: SOFTWARE
          Bilyahn is correct. Launch the add printer program and follow the option to allow windows to find updated list of printers.
          it takes a few minutes but shows a much more comprehensive list and the ar275 is among them.
          Bill
          • btbear
            Re: SOFTWARE
            We have had some luck loading the windows 7 driver for the new version of the machine. You might try using that AR-M257 PCL driver. You have to load the driver as if the MFP is connected by USB then add the network port later in the printer properties.
