Max number of pages reached see admin
  • benn84
    • Jan 2011
    • 26
    [Error Code] Max number of pages reached see admin
    Hi
    I'm getting an error message saying 'the Max number of pages has been reached see your administrator ' and the copier will not function, its an mx2600
    Regards
  • divad2k1
    • Sep 2010
    • 147
    Re: Max number of pages reached see admin
    Is account mode enable ? If so , you have probably reach your page limit.
    • igi
      • 1507
      Originally posted by benn84
      Hi
      Regards
      hi
      step 1-make sure with the person/boss who is in charge of the copier, that is ok to reset this account
      maybe its limited for a reason.
      step 2- log in as administrator into a copier go to user control and reset the limited account
      good luck
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • Ednicarl20
          • Aug 2011
          • 25
          Check the system setting & then look for the user control. Check what are the setting In page limit group list. You can check also in "copy setting" look for "other setting" and check the "setting a maximum number of copies"maybe it was set to a specific copies. Hope this will help...
          • nightshade
            Chromographic Supremesist
            • 158
            What you are getting is NOT an error message, it is a notification.
            Do what it says, "Contact your Administrator" if you are the admin, time to get out the user manual.
