AR-208D Scanning
  • RSCA
    • 112
    AR-208D Scanning
    The scans come out light and fuzzy. The customer can scan the same original on his home machine with no problem. Copies look fine. Pulled the scanner and cleaned it. I bought the gray gradation chart and did the black level adjustment (63-02). It showed OK at the end, no errors. There was no change in the scan quality. Any ideas?
  • igi
    • 1507
    Re: AR-208D Scanning
    hi
    we dont have this model but scanning is same
    1-do you scan usb or network
    2-which application do you scan with
    cheers
