ar-bc260
  • ADVANCEDCOPIER
    ar-bc260
    I just got this machine in and printed out 22-6(copy looks good), machine was in f9-00-found out some one took the hard drive and the p-19 nic card, so I replaced it with a p-16n,hard drive,and p-19 nic from an ar-bc320,now it shows the boot,pcl and nic rom in the machine with 22-5 with latest firmware. the problem I'm having now is that when you print in black they are all solid black copies,like the lamp is out. when you print in color the copies are dark black but you can see your origonal in the background. any help would be appreciated. jd
  • choicecopyguy
    • Mar 2006
    • 111
    I would try reflashing the roms first. The nic should not affect this or the f9-00. Do you maybe have another HD?
