mx 4100 wavy background
  • ash_572
    • Oct 2008
    • 523
    i have a mx4100 which has only done 70k in b/w and 50k in colour. in the sample the background is suppose to be light blue. instead im getting wavy yellow and blue.
    i mainly work on ricoh. any help is appreciated.
  • mojorolla
    The Wolf
    • 2639
    Re: mx 4100 wavy background
    The blue ribbon appears fine and the waves are only inside the blue border. Is this a print or a copy job? If print: try adjusting the advanced color settings in the print driver or try a different driver. If copy: run shading execution for the scanner, SIM 63 I think. Has the machine been color calibrated recently? Always a good start with Sharps.
    I had a similar problem on a smaller color Sharp (MXC311), where a certain file that was blue would render in a slight purple. Changing the advanced color settings solved our problem.
    • Dark Helmet
      • May 2009
      • 868
      I would calibrate your engine as Mojo suggested. Try a differnt document and see what happens. Are you using postscript? Some times the PCL drivers don't do a very good job of producing the right colors.
      Calibrate your engine first, if your still having issues change the driver to a PCL5e or a PCL6. Postscript is best if the machine has it.
      Ive attached a color calibration cheat sheet. Don't perform sim 25-2 on a Sharp unless your changing DV.
      You can't do sim 63-3 with out a SIT chart or sim 44-13 with out the jig.
      This machine has 46-74 (does copy and print together) so you can skip doing 46-24 (copy) and 67-24 (printer)
      • ash_572
        • Oct 2008
        • 523
        this is a print job. copying colour is fine. in the sample i have shown, inside the border is suppose to be a light blue colour. insted iim getting yellow bands in some areas.
        i will try to do the colour calibrations on next visit
