No blue color printing sharp 2300
  • gerardo
    • Jul 2025
    [Error Code] No blue color printing sharp 2300
    We have a code. And we replace dev. DV Unit and Drum. The3 blue color keeps fading.
  • igi
    • 1507
    Re: No blue color printing sharp 2300
    hi
    what code do you have, it will help us to help you better
    good luck
    • Sam Tofu
      • Dec 2007
      • 130
      Yes error code will help a lot. From your post am I correct that you replaced both the developer and the developer unit? Developer has to bought in a tricolor dev pack (expensive and DV unit is expensive).
      Often fading (depending upon type of fading) is caused by the Master Charge Screen grid for the drum.
      Developers usually go way beyond the rated life.
      Also in answer to your OCE Imagistics POST, there isn't a "chip" that is used for the 2300.
