Authentication on mx3110n
  • foudl
    • Mar 2010
    • 138
    [Misc] Authentication on mx3110n
    Does anyone knows how to set up authentication using numbers only (simple method would be be greatly appreciated)
    I'm looking into the user manual but can't find any useful help
  • mojorolla
    The Wolf
    • 2624
    Re: Authentication on mx3110n
    The manuals are built into the machine on these models. The simple method:
    -login to the web page as admin
    -go to user control, default settings and turn on user authentication and check the box for user number. Hit submit
    -you can now create users and assign them a user number.
    -if they are printing, the user number is entered in the "job handling" tab
    Be sure to turn authentication on BEFORE creating users as this can cause issues.
    • foudl
      • Mar 2010
      • 138
      User control- turn on user authent. -check the box for user number- hit submit everything is ok so far ...but how do i create users and assign them a number
      • Horologydoc
        • Jun 2011
        • 61
        You will do that in the web interface as well.
        Go into the user control section and select "add."
