Sharp ARM550N Scans Aborted
[Error Code] Sharp ARM550N Scans Aborted
It does not matter how slowly you go as long as you do not stop. –Confucius
Re: Sharp ARM550N Scans Aborted
I got it, I was doing it wrong, "Your Doing It Wrong!" ha, ha.
If one is going to select the original size manually in Image Send: you must change it under the Scan Size Auto button, NOT the Send Size Auto button. They are right next to each other and only one word different, Shheesh.It does not matter how slowly you go as long as you do not stop. –Confucius
Re-SubscribingIt does not matter how slowly you go as long as you do not stop. –Confucius
