Sharp mx-2700N Ripping Issue
  • Resource Group
    • May 2025
    Unit was disconnected and moved to another room. It has worked fine since purchased. Copies fine but when attempting to print "Data" light flashes and machine is locked up. In the print Queue it reflects any document that is trying to print as "Ripping". I can not get the firmware that is one the machine as it will not print. Any help would be appreciated.
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Re: Sharp mx-2700N Ripping Issue
    Was there a Print Server connected to the machine at it's previous location...such as a Fiery Controller or similar print server?
    The term "ripping" tends to be used by print servers.
    Where a normal pc will use a "Print Spooler" to rip the job a Print server or Fiery uses ripping to compile the print jobs faster.
    I would have your I.T dept reconnect the print server in the new location and failing that I would have a Sharp tech attend the machine and turn of the Print Controller option via service mode.
    • igi
      • 1507
      hi
      could be mems
      mory or hard drive problem
      firmware can be obtained via display with sim 22
      cheer
