ZOOTECH, and about drives, wath you think
Sharp AR-M450
There are some problems with PCL6 with some applications, PCL5c/e is better in most cases. Postscript is needed for MAC environments or for fine graphics.
Postscript is an option for each machine and requires a product key, like the ARP14."You can't trust your eyes, if your mind is out of focus" --Comment
First, a correction to an earlier post of mine; the ARM450N has only one slot for additional memory.
With the AR407, you will not see much difference in speed. Is the print controller maxed out with additional memory, this might help speed wise?"You can't trust your eyes, if your mind is out of focus" --Comment
ok ZOOTECH, y saw the slot in the ar-m450n and there is yes, y put one of 128 mb and it better for read much more original.
and yet about the 407, this is possible upgrad memory?? where is the slot?? and the memory is the same of the 286/285/335 ....???
thanks, very much for your atention whit my questions in this post.
byComment
The print controller is the ARPB2A which has two slots for additional memory. The memory is a standard 72 pin SIMM, max size is 64MB total for the two slots. With the base memory at 64MB, the most you can get then is 128mb."You can't trust your eyes, if your mind is out of focus" --Comment
Ok ZOOTECH, y do the simulation 22-6, and y saw that there are hdd 10gb, and memory 32 mb?? this memori is of the copier or the ar-pb2a??
- y understand that , y can colocat or two memorys of 32mb, or two of 64mb or yet two of 64 mb??? in the ar-pb2a.
-and the copier, there are not memory to??Comment
TC 22-6 is showing the copier's memory and HDD. The print controller can only take 16MB or 32MB (not a 64MB or 2x64MB) in the two additional slots.
Take the printer 'Off-Line' > Menu > test print> configuration page ---this should show you about the print controller.
Is it time for tapas and sangria yet?"You can't trust your eyes, if your mind is out of focus" --Comment
oK ZOOTECH, y understant every thing.
And about tapas and sangria is more in spain , y am portuguese , ours is mor oport wine of douro, and codfish ah, ahvery good.
thanks a lot, for your help.
ding-o@sapo.ptComment
