MX-503U Usb Port Not working.
  • nobody-here
    • Mar 2008
    • 237
    Hi guys,
    suddenly my frontal MX.503U USB Port stopped working, asking me to re-install drivers.
    I checked lcd panel, and "standard driver" is selected.
    Do you think firmware upgrade is a solution?
    Thanks.
    Vincenzo
    29 rouge unpair manque.... cous cous....
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: MX-503U Usb Port Not working.
    Located in the upper left corner of the MFP PWB are 2 dip switches, the lower of which controls the front USB port. When set to OFF, the front USB port works, and likewise when set to ON, the front USB port is disabled.
    I'd suggest checking these 2 dip switches to see if it was disabled.
    • nobody-here
      • Mar 2008
      • 237
      thanks a lot.
      that's it.
      dip-switches were in wrong positiion.
      Regards
      Vincenzo
      • Akitu
        • Oct 2010
        • 2595
        You're quite welcome.
