F6-21 MXC311
  • Dark Helmet
    • May 2009
    • 853
    F6-21 MXC311
    Hey guys,
    I got a MXC311 with a F6-21. You have to go into the MXFXX3 SM to get the codes. Code says the LIU board location code differs from the Fax pwb. Over a year ago this copier was throwing this code and i swapped the entire fax kit out. From what i remember i did enter sim 66-2 and checked that the location code was set to USA.
    Ive seen this before on a MX2600 and power cycling it fixed the problem. Every now and again it would come back but again a power cycle would get rid of it.
    I have not been able to get the customer to power cycle yet as it was a boss that called in looking for the salesman wanting to cancel the contract and he was unwilling to work with me on the phone.
    Has anybody ever run into this code before and did they have a fix for it? I imagine a power cycle will reset it for now but it should not be doing this. Is it possible for a outside influence on the machine to cause this problem? The 2600 mentioned above is now being used by my office for the last 3 months and it's never had a issue, however the code had not shown up for over a year before we pulled it from the customers office.
  • mojorolla
    The Wolf
    • 2622
    Re: F6-21 MXC311
    Sharp fax kits are a little too picky for my liking. I have seen a lock up state of the fax memory freeze an entire MFP many times. 66-10 will dump out all the junk. You may also want to check 66-39 destination setting as well. I have only had that code once and after resetting the destination, it has been about a year.
    I hope I didn't junk jinx myself.
