AR-M550N Scans Have Line on Left Side
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    [Misc] AR-M550N Scans Have Line on Left Side
    We have a Sharp AR-M550N we are scanning to folders with via Sharpdesk 3.3 through the ADF. When they pull up the scan on the PC and re-print it there is a line on the left side from top to bottom. This line never occurs when making a copy and when the scan is reprinted the overall image is smaller than a copy/original.
    It does not matter how slowly you go as long as you do not stop. –Confucius
  • bilyahn
    • Dec 2006
    • 1470
    Re: AR-M550N Scans Have Line on Left Side
    Did this just start happening? What does their condition settings show when they scan? Does it also happen if it is scanned off of the platen glass? A couple of things to check. You can go into system settings and check what the default scan setting are (they might be set to something other than default). Also check your sim 50 default setting for scan. Does it have latest firmware?
    Good luck.
    Bil
