POD2_S
  • Tewwk65
    • May 2011
    • 12
    POD2_S
    I have 2 MX2300N doing the same jam code.POD2_S.As the paper enters the duplex it just stops!Can run single sided all day.Just as it enters the duplex.Replaced the sensor still does it.Any one seen this?
  • brewster67
    • Jul 2011
    • 167
    Re: POD2_S
    I would check the reverse gate on the door to make sure that it is not warped or cracked causing the jams. I would also check the APPD1 sensor to make sure that it is working. There was a bulletin (MFP-TB-376) about the APPD1 sensor. Hope this helps.
    • mojorolla
      The Wolf
      • 2626
      Re: POD2_S
      Check the springs on the top baffle of the right door. If they fail, when the door is closed, the baffle sits on top of the duplex entrance gate.
      • JustManuals
        • Jan 2006
        • 9838
        Re: POD2_S
        Paul@justmanuals.com
        • Tewwk65
          • May 2011
          • 12
          Re: POD2_S
          Well today swapped out the whole right door assy.Still does it.POD2_S is the exit sensor code.Going to try turnover assy Friday?the sensor checked out fine.....Man theres days i hate this job!!! Any ideas?
          • MarshallB
            Re: POD2_S
            I am having the same problem on a 2700. I had to go in and clean off the POD2 sensor and while it works fine now on single sheet copying, the duplex stops exactly where you say yours does. I am going to try and clean the sensor thoroughly and hoping all it is that I didn't put it back together last time properly. Please post information if you have solved this problem.
            • PASTech
              • Sep 2010
              • 192
              Re: POD2_S
              I had a machine do the same thing. Runs single sided all day but duplex it fails. My problem was with the 2nd transfer-belt. Some how the two black brackets that you put on in order to apply the stretch or rather the inside pressure to the belt had been swapped, front to back and back to front. Very small problem that meant the transfer had a slightly greater angle causing it to jam on the switch gate when doing duplex. You said you replaced the whole door unit? did that include the 2nd transfer?
              Hope this helps (I think there was a bulletin about this)
              What's Brown and Sticky?
              -A Stick
              • stech
                Re: POD2_S
                replacing the exit unit has fixed POD2 jams for me. You might want to check the energy save feature. If this is set too high it can cause warping and damage to the exit unit/right side door. I know most people want to walk up and make a copy instantly so sometimes it's not possible to lower these settings.
                • warhawk
                  Re: POD2_S
                  I had a 4501 that would do this also. Mine was a fused problem, Can't recall what it was we swapped fuses.
