scan to Network folderfor Mac osx
+ More Options
Posts
  • redserv
    • May 2010
    • 307
    hello guys can someone point me to a TT that can tell me the procedure for scan to shared folder with MFP MX-2610N to a Mac?i am not really familiar with the mac,and i really need some help, thanks in advance.
  • TheOwl
    • Nov 2008
    • 1732
    Re: scan to Network folderfor Mac osx
    Konica Minolta Apple Mac Scanning Guide V1 0.pdf
    I know this is for Konica Minoltas, but at least it gives you an idea of how to setup the Mac and then everything else from your machine should be the same as scanning to a Windows files share.
    Now, if you are trying to scan to OSX 10.7, then you are out of luck as the SAMBA protocol within 10.7 has changed and you will find that just about all copiers aren't compatible with this.
    • redserv
      • May 2010
      • 307
      Originally posted by TheOwl
      [ATTACH]14434[/ATTACH]
      the owl you're a life saver been looking for this information and could not find it, thank you very much really appreciate it
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        One small gotcha: If you are using the Mac's hostname instead of IP address in your SMB path (either is fine), the maximum number of characters is 15.
        It took me a day or so to figure that one out an account last year.
        • RRodgers
          • Jun 2009
          • 1947
          It wasn't that had back when I did it on a Konica. I just ended up googling "scan to smb 10.5" or whatever version of the OS I was on. Found an answer pretty quick and I was pretty surprized how easy it was to do.
          • redserv
            • May 2010
            • 307
            yea for some reason i could not find anything on it, when i did it a couple off weeks ago i got selected server could not be found, but i suspected the folder path was not right,i'll try again tommorow at the customers site.thanks again guys.
