Scan to Email Exhcange 2010 Issues.
  • Ricefoxnz
    • Jul 2008
    • 30
    Hey fellow techs.
    I was wondering if any of you have had much experence with getting exhcange 2010 working with any of our copiers without comming up with "Authentication type not supported"
    Emails work fine with no authentication internally but as soon as I try and send externally I get the basic lost comunication error.
    I have tried every method of authentication I can think of.
    domain/user
    user@domain.local
    user@domain.com/whatever
    user
    anon
    SSL etc.
    I have tried setting up the copier to have it's own account with it's own email. Still the same error.
    I know that 2010 now has diffrent authentication that only really works with the latest office products etc, and by default does not use plain txt authentication anymore.
    I have fixed the issue at some sites by getting the clients I.T to setup relay, but on 2010 it is quite hard to setup now from what it used to be on 2003/7. But a lot of I.T people now will not setup relay as it opens up all ports and what not. There is a way to setup sequre relay but it is quite complicated.
    Any help would be great thanks!
    Isaac
    So have you guys found a way around this or come into this issue?
  • Ricefoxnz
    • Jul 2008
    • 30
    Re: Scan to Email Exhcange 2010 Issues.
    After doing some poking about I found this.
    Allow Applications to Send Email Through Exchange 2010 - Matt Williamson's Blog
    I followed this and it sorted it out with no authentication at all!
    • ZOOTECH
      Senior member of CRS
      • 3377
      Nice find, I know we will be using this setup at some time in the near future. Tks...
      • TheOwl
        • Nov 2008
        • 1732
        Email with Exchange 2010.pdf
        With Exchange 2010, you would need to use the following settings all together to get it running:
        SMTP Authentication
        Use TLS
        Have a registered Mailbox with the correct email address
        If you follow through the docco that I put together, it eliminates all of the above.
