If I try to print a pdf from a flash drive I can only see folders, no files.
MX-2600N I'm trying to print from a flash drive
Re: MX-2600N I'm trying to print from a flash drive
No....
I thought the Post Script kit was neccessary for Mac printing.
I can load PDF files on a flash drive and when I go to Document Filing
and go to Ex data access and select USB memory I can see folders but no files!
I did check a MX-2300N it has post script on it and I can see the files but it asks for a password to printComment
I think PostScript is needed to print PDFs. To make sure there is no issue with that copier seeing files, create a TIFF and put it on the flash drive and see if the copier can see it and print it. You do not need PostScript to print TIFFs.Comment
