AR-M550 PM Checklist
  • Don N.
    • Nov 2011
    • 409
    Customer has F2-37 drum mark code, failing cleaning blade at sensor mark and rotational wear at front. Anybody have a pm checklist for the AR-M550? Need to quote a customer that's been alienated by recent Sharp dealer change of hands. Meters read 230k on total, dev, maint, drum... Curious if the transfer belt needs replaced at the same time as drum, dev? Is the transfer belt an assembly, or separate belt/blade? Also line forming at thermistor or t-fuse. Is this a well advised fuser rebuild, or assembly needed? About to go fishing for parts & svc manual. Got burnt by online manual, turned out to be the circuit diagram only! Thanks much.
  • rainmaker
    • Jul 2011
    • 77
    Re: AR-M550 PM Checklist
    the pm for the ar550...the drum ar 620 dr,dv ar 620 nd x2(two bags) maint.kit ar 620 ka,transfer kit ar 620 kb,the fuser rollers ar 620 uh,620 Lh are rated at 300k.i would check the cleaning blade to make sure its cleaning the drum mark.i have seen the drum blade fail before 300k,also i wouls make sure the drum mark is good,not worn,and i would also run test command 44-2,if you replace the drum make sure you run this test command.hope this is helpful...good luck.....the 620 kb (transfer kit) has a transfer belt and two rollers.
    • Don N.
      • Nov 2011
      • 409
      Thanks Rainmaker. Cust says they've had it for 7 years. Front of drum is worn down to core. I could just change the blade that's streaking at the drum mark, but with 230k & 7 years, the solids aren't so good. Wouldn't you recommend a full pm?
      • rainmaker
        • Jul 2011
        • 77
        yes i would don.after that many years i would do a full pm.i would do all the paper feed rollers also,dont forget the doc feed rollers.good luck don
        • harleyrider
          • Oct 2011
          • 348
          I replace fuser as a assembly. There has been a few upgrades on them. AR-703FU1. Also the pm kits have new developer side seals so the drum wear is better.
          • Sam Tofu
            • Dec 2007
            • 130
            The only reason I would also lean towards a full PM is the low meter plus years on it. We have a number of this series 550-700 that have 750 to 1.4 million where we usually got 500K on drum and developer and usually 700K on the transfer.
            The biggest issue has been the fuser and as mentioned in post it has been upgraded a number of times. The part number listed above in posts is the most recent. And it is easier and cheaper to simply replace whole unit.
            Most of the items that are PM items are available waaaay cheaper that ordering them as parts.
            Here are 2 places you can get supplies wholesale and you can also order parts with direct ship to you via Sharp through them
            Robert Duchess
            West Coast Sales Manager
            Collins Distributing Company
            13929 Equitable Road
            Cerritos, CA. 90703
            800-727-0884 x2755 Toll Free
            562-991-5061 Local
            888-232-1945 Fax
            THEY also have a East Coast Distribution main branch
            DC Wholesale
            (Minn.) 800-735-3018
            Fax 952-707-1288
            • Sam Tofu
              • Dec 2007
              • 130
              I have attached a "Sharp Handi-Guide" that should be of some help.
              • Don N.
                • Nov 2011
                • 409
                Thanks Sam. Very helpful for pm. Noticed your in Fl., but gave west coast Collins info? Been using Collins on east coast for years. Excellent source for Sharp, Samsung. Much appreciated. If anyone has full PG or SM, I'd love to "borrow", and return the favor.
                • Sam Tofu
                  • Dec 2007
                  • 130
                  Was in FL for long time now out West Hence the CA Branch for Collins. Check your PM.
                  • foudl
                    • Mar 2010
                    • 138
                    WOW i have two machines like this and they have 7.5 millions copies each ,do the maintenance as request every 300k and let it go ,is there someone else with that much copies on their machines
                    • DavePo
                      • Jul 2008
                      • 303
                      Yeah we have one in our service dept that was traded in at 8.7 million and we are going to use until at least 10. Never seems to have a problem.
